Rear End Does a Wiggle During 1 - 2 Shift
Old Nov 28, 2002 | 01:11 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Hi gang,
My 86 Sport Coupe 305 700r4 has always done a little wiggle when it does the one - two shift, when I'm giving her a good dose of the pedal.
Does anyone else's do that and what might be the cause of it?
Old Nov 28, 2002 | 02:28 AM
CrazyHawaiian's Avatar
Car: too many ...
Worn out bushings in the rear. Get the full poly kit for like $130 or just buy the rear pieces individually. How many miles on the car?
Old Nov 28, 2002 | 04:41 AM
Engine: 305-4v
285,000 km.
Old Nov 28, 2002 | 08:02 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Mine does that, but I have a shift kit in it. When it shifts from 1-2 at WOT, it breaks the tires loose.
If you ever watch on TV when they do runs on the street with high HP engines, and they are filming directly from behind the car, you'll see the back end break loose and shift a bit. It's the engine over powering the tires.
Old Nov 28, 2002 | 08:55 PM
Engine: 305-4v
Mine has a pretty hard 1 - 2 shift alright, and it does make the right rear break loose and chirp. And it is sort of cool when it does the wiggle
Makes it look like it's packing serious hp
Old Nov 28, 2002 | 10:12 PM
iroc22's Avatar
I'm not exactly sure on what the 'wiggle' is, but one suggestion could be bad wheel bearings on one side, especially with those high KM's.
Old Nov 28, 2002 | 10:34 PM
formul8!!'s Avatar
Car: 2004 GTO
I added BMR PHR and LCA's and it got rid of that problem.
Old Nov 29, 2002 | 12:30 AM
Engine: 305-4v
No, I just had the rear end rebuilt.
It's pure hp, man!
Old Nov 29, 2002 | 03:08 AM
Yep, it sure does.
Old Nov 29, 2002 | 11:40 PM
Car: too many ...
Oh sorry I didnt know you were loosing traction, I thought the car was just wiggling back and forth. Maybe try some aftermarket LCA's.
Old Nov 30, 2002 | 01:25 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
hmmm.....well i would say that in order to stop that you have two options:
1. Purchase a 2x4 of wood and place under pedal to insure no WOT which may cause tractions loss.
==OR==
2. Purchase one dozen eggs as this may take some getting used to. Place an egg under the gas pedal, everytime it cracks try a new one until the egg no longer cracks and your traction problems should be solved.
Old Nov 30, 2002 | 04:06 AM
Engine: 305-4v
I'm not really losing traction, just getting a chirp on the one - two shift from time to time.
Old Dec 1, 2002 | 01:34 AM
NTChrist's Avatar
Are you still running the stock shortblock, dude?
If so, congrats! I like to see people getting their money's worth out of an engine.
EDIT: Wait a sec, I just realized that I have 249,000 kms, so I guess your mileage isn't TOO far off!
Old Dec 1, 2002 | 03:49 AM
Engine: 305-4v
Yup, shortblock is stock. About the only stock part left
Old Dec 1, 2002 | 11:30 PM
MdFormula350's Avatar
if everythings been replaced and nothing is loose then your just losing traction it seems..
Old Dec 2, 2002 | 11:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Y'know, we can fix that.
So you gonna come out here in spring so we can line 'em up?
Old Dec 2, 2002 | 11:43 PM
Engine: 305-4v
I know--just gimme your 400
I was gonna ask you when you were coming back to Cowtown?
Old Dec 2, 2002 | 11:53 PM
AFreaknGoodTme's Avatar
Things are just pulling to one side or the other slightly while the posi slacks and the reingages into second gear. This is why true drag cars run spools so they don't get any side to side action.
Old Dec 3, 2002 | 01:00 AM
Engine: 305-4v
I don't have a posi.
Old Dec 3, 2002 | 01:04 AM
Then that really explains things. It'll move to a side even worse with an open axle.The power is routed more to one side than the other.
Old Dec 3, 2002 | 11:18 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Umm.. no. But if I get rich again any time soon then I might know where you can get a used 385.
I don't have any plans to go to Calgary in the forseeable future.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
