Pressure on pedal, but not much breaking action
My 'Bird's been off the road for about a year, but I now have it almost in running condition. One problem is that when I hit the break pedal, there's what seems to my foot to be normal pressure on the pedal, but I really have to stomp on it to stop. Is that air in the lines, or is something else weird? I know I have vacuum going to the break booster, but could the booster itself be shot? Or is it air in the break lines and i need to bleed them? The front pads have only a couple hundred miles of highway on them, so I know they're fine, and the rears aren't that old. And the breaks worked OK before I put the car in the garage to put the new engine in.
Car: 1984 F41 T-Top
Transmission: 5 speed
If the pedals are soft or very easy to hit the back plate then you have air in the lines. Brakes should have a firm to hard feel to them... bleed the brakes and check the fluid level.
Car: 1984 F41 T-Top
me bad ... sorry about that.
Try this page, http://www.mpbrakes.com/troubleshooting.htm
I don't know what type of braking system you have but this page should help you narrow the problem.
Night rider327
Sep 2, 2015 04:17 AM
