swaybar sizes
Old Nov 28, 2002 | 06:53 PM
Trent257's Avatar
swaybar sizes
i have a 90 iroc-z what are the sizes of the swaybars? im thinking about spohn which are 1 5/16" front (solid) & 1" rear? worth it?
Old Nov 28, 2002 | 10:13 PM
iroc22's Avatar
Does it have FE2? I'd venture to guess that you have the 36mm hollow front bar and 24mm rear solid.
Old Nov 29, 2002 | 05:43 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Check your suspension RPO code and then run the numbers.
Ed
Old Nov 29, 2002 | 01:06 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
its an IROC, not a 1le or w6s,
chances are it is 34mm/23mm.
Old Nov 29, 2002 | 01:09 PM
Trent257's Avatar
yea its not a 1le
so i would get better performence with spohns swaybars?
Old Nov 29, 2002 | 01:13 PM
Dewey316's Avatar
Car: 1990 Camaro RS
well yes, they will be very stiff.
you could also go to the 1le size bars 36/24
it doesn't sound like a big diffrence, but it is VERY noticable. also going to a good set of poly bushings will help it too.
also, if you are looking to tighten up the cars handling, new springs will really help that too, if you are still on your factory springs.
and of course, sticky tires make a HUGE diffrence in how well the car handles.
Old Nov 29, 2002 | 01:21 PM
Trent257's Avatar
i have eibach sportlines in, in a few weeks i will be ordering spohn sfc, lca and relocator brackets, and panhard bar. im not driving the car over winter, so i probably wont get new tires till spring or summer, ive been looking at the bfgoodrich gforce t/a kd's.
just wondering if the spohn swaybars will help me at all or if mine are big enough?
Old Nov 29, 2002 | 01:28 PM
Dewey316's Avatar
Car: 1990 Camaro RS
well, they wont hurt
with the eibachs, and those sway bars, you are going to be ON RAILS.
Old Nov 29, 2002 | 01:49 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
CAREFULL
be carefull not to get too big of bars "I" have found the 34/24 combo for AUTOX works well or the 36/24 combo for road race works well...
BUT, it all depends on the rest of the combo, spring (eibachs are a good choise BUT pro-kit is better than sportline) shocks (koni, bilestein, etc.) SFC's, LCA's bushings, etc. etc. etc.
Old Nov 30, 2002 | 03:15 AM
iroc22's Avatar
Some FE2's had the 36/24 combo. My IROC vert had em.
Old Nov 30, 2002 | 10:52 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Re: CAREFULL
Bumpa,
Would you please qualify your assessment of the pro-kit springs being better than the sportlines.
Thanks.
-Schultzy
Old Nov 30, 2002 | 11:16 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I've got the 36mm up front and recently came across a massive 28mm (1 1/8") rear bar at the wreckers.
That rear bar is like a gift from the gods, I can finally oversteer on demand and it stays flat like I've never experienced before. I hunt corners down now.
Old Dec 1, 2002 | 05:05 PM
BumpaD82's Avatar
Re: Re: CAREFULL
Originally posted by Schultzy89GTA
Bumpa,
Thanks.
-Schultzy
The sportlines look better (more drop) but other than that, the Pro-kit will out perform them, I've tried both and pretty much every 3rd genner autoX'er I know RELY on the pro-kit... My current combo is Monroe front stuts (weak link) GM 34mm hollow sway bar, and pro-kit fronts... GM brand IROC replacement rear shocks, with 24 mm GM sway bar, and stock GM IROC springs rear... but my combo changes all the time, depending on events... especially the rear springs (stock, sportline, pro, v6)
Pac J
May 17, 2020 10:44 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
