Power brake booster question...
Car: 1987 Z28 Convertible
Transmission: 5-speed
What is the minimum vacuum required to power one of these? Ever since I swapped cams, my power brake assist fades away under moderate brake pressure. I now produce 13 inches of vacuum at an idle and know of others who don't have this problem. Therefore, I'm leaning towards a bad booster. Does anyone know how to test this? Thanks for any insight, guys.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
13 inches is fine. Problems start when you get below 8".
Check the vacuum line to the booster. Make sure it's not leaking.
