Which rollcage/bar would be better?
I'm doing a rollcage this winter and am gonna order a kit and customize it to fit my car. I got in photoshop and made a really bad rough draft to see which way would be stronger. I know the full cage would be but how much stronger? is it worth the bars in teh way and such? thanks
ya that is kinda what I"m thinking but only make it 4 pt. so peopel can still ride in the back and it will be somewhat "hidden" thanks for the pictures. I think I'll go w/ that one.
Josh
Josh
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Here's the Jeg's kit also, took 4 hrs to install from the time the chop saw fired up till the last coat of paint, I've done alot of welding/fabricating so that helped, but the kit is'nt too bad for the money. Bought the 8 point but only made it a 6.
back shot
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
87transam5.7tpi
Since you're only considering a 4 point without a cross bar so that people can ride in the back then the roll bar is cosmetic only. If the car ever runs 11's it won't be legal.
I have an S&W 8 point in my car. every bar had to be cut to length which surprised me b/c every bar end looked like it was plasma cut for a clean easy fit the way it was shipped. the bar is great but did take alot of work to get everything done. I have to agree w/the one guy above that a 4 point is cosmetic only. if you are going to strip your int to put this in you might just as well put in a min of 6 point w/the cross bar on the hoop behind the 2 front seats. be sure to have an angle grinder handy alog w/the wire feed.
It was a PITA for me too. I have my headliner out and left enought room to slide it back in, so there was a little room to get the gun up in there.
Originally posted by Stephen 87 IROC
87transam5.7tpi
87transam5.7tpi
