1le rear sway bar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
1le rear sway bar
i have a brand new 1le front sway bar now i need to get the 1le rear sway bar. is it still available from GM??
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
I don't think they are still available. I have checked GMPartsdirect.com and found nothing. Maybe someone else knows better than I.
If you need part numbers for 1LE/WS6 swaybars, bushings, and endlinks try this old post. Look for JamesC's replies.
https://www.thirdgen.org/techbb2/sho...bar+bushing%2A
Edit: I would PM Lonsal, he would surely know the answer you want.
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
they are still avavlible..
they are still avalible from gm..
Part #
10035033
BUT this is a MUCH better deal powdercoated and all:
http://www.top-downsolutions.com/pro...products_id=55
Part #
10035033
Axle/Gears: 3.45, 3.27, 3.27
FYI, I only have 23mm or 24mm in powder-coated red in stock at the moment.
Lon Salgren
Top-Down Solutons
Lon Salgren
Top-Down Solutons
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
