9-bolt disc brake backing plate q's
Old Dec 8, 2002 | 08:13 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
is there a difference in the backing plates for the stock cast iron and the pbr l1e calipers? If so, how can i tell the two apart? i have a 9-bolt and id like to get calipers for it but i dont know if there is a difference between the backing plates.
Old Dec 8, 2002 | 10:37 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
I believe the early non-PBR type backing plates are cast iron, and the later PBR type are fancy stampings.
Thanx,ANDYZ28
Old Dec 8, 2002 | 10:42 PM
Car: 88 Camaro SC
Engine: SFI'd 350
dammit... hoping to get away with using the cheapo cast iron ones... guess that explains why the bolts where missing. the guy porbably had to use them to bolt the retro fit plates to his 10-bolt. Oh well... ill probably cop out and replace them with the plates for the drum brakes. Too broke to afford anything better.
Old Dec 9, 2002 | 12:35 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Although you can't really see the plate, this is what the "old" style backing plate looks like. This is (was) my '88 rearend:
Attached Thumbnails 9-bolt disc brake backing plate q's-old-rear-prior-removal
Old Dec 9, 2002 | 12:37 PM
ebmiller88's Avatar
And this is my "new" '89 disc rear PBR-style backing plate. Andy sells these plates for the upgrade, I'd contact him:
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
