90/10 and 50/50 on stock suspension??
It should help tracion...however, if you drive this on the street...(not sure if you do or if it's a track only vehicle) it won't corner very well at all. so a turn that you could take at 55 before....you may find yourself in the ditch or wrapped around a pole after putting those shocks on. Just a heads up.
Thanks! That's what I have heard about losing some handling, I don't really mind if I gain a lot of traction. I do drive the car on the street, but it is not my daily driver. Will it still be safe as long as I am careful?? Anyone else running this setup on the street??
Car: 88 Camaro
Engine: 355
Transmission: TH-350
The 90/10 struts will make the drastic difference in handling and traction. The shocks will make some improvement. If you do some street driving, go for the 70/30 struts and the 50/50 shocks.
Good Luck.
Good Luck.
LT1Formula
Nov 16, 2015 01:13 PM
Genopsyde
Oct 7, 2015 08:35 PM
Dialed_In
Aug 20, 2015 01:45 PM
