PBR rear disc?
Old Dec 11, 2002 | 05:06 PM
Kandied91z's Avatar
PBR rear disc?
is there a way to make or purchase a bracket that will extend the mounting point of the stock PBR caliper on setups such as my stock rear?
i'm looking to fit some eradispeeds and the stock bracket for my pbr is a little to small. would it be possible to use the corvette brackets for an application like this since their calipers are similar? it only needs to move a tiny bit, but so much that your stuck purchasing smaller rotors.
baer makes a touring system that uses our exact calipers but has this bracket that allows for the eradispeed 12" rotors. anyone have these and know if the bracket can be duplicated?
Old Dec 12, 2002 | 06:15 PM
Kandied91z's Avatar
no one has ever attempted this??
Old Dec 13, 2002 | 07:41 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'm having trouble getting a visual...and I thought 'Vette and Camaro rear caliper carriers were the same, but the 'Vette ones had "Corvette" cast into them. If you're set on going with Baer, I'd call them up and talk to a techie. Mybe they can help you out. Other than that, I suspect you'll be up to fabbing up your own.
Sorry I'm no more help.
Ed
Old Dec 13, 2002 | 11:35 AM
Kandied91z's Avatar
not a problem.............
i don't know what the piece is so it's hard to explain......maybe the caliper anchor? it's the bracket that attaches the caliper to the hub of the rotor...on the vettes and similar with the touring package it's extended a little more to fit a larger rotor.
Old Dec 14, 2002 | 03:28 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
"Vette" caliper carriers will not work on our cars. I already tried it.
Thanx,ANDYZ28
hectre13
Dec 11, 2023 08:14 AM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
