Adjustable rear spring perch insert for a 4 or 5 inch spring?
Old Dec 18, 2002 | 06:00 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
Does anyone have or know where to get a adjustable spring perch for the rear suspension? It allows you to run a 4-5 inch spring that can be bought in different load rates. Anyone?
Old Dec 18, 2002 | 06:39 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
ground contol sells a rear spring pear for a 5.5 OD rear spring. i am not sure how much shorter than stock you can make it (i think probably 4-5" of adjustment.)
Old Dec 18, 2002 | 08:11 PM
AFreaknGoodTme's Avatar
I have made some custom brackets for the upper rear spring can so in the future (someday when I get the extra money) mount coilover shocks in the rear. What these brackets do is they will distribute the weight load of the car that will now rest onto the weak upper shock i-bolt mount back to the can area where the original coilspring rests holding the weight of the car. Diagram below.
Old Dec 18, 2002 | 08:34 PM
hillbilly pic- This isn't working, I can get the size correct.
Attached Thumbnails Adjustable rear spring perch insert for a 4 or 5 inch spring?-upper-strut-mount.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
