Spring rates
Old Dec 18, 2002 | 09:10 PM
86 IROC's Avatar
Spring rates
Does anyone have a fairly complete list of spring rates for 3rd Gen front coils? My car sat too high for me w/ stock front coils, and now it is too low for the LT's w/ Eiabach Pro's. I'm looking to raise it back up 3/4" - 1.125" - Thanks in advance.
Old Dec 18, 2002 | 09:41 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
www.groundcontrol.com
you can get a setup of coil overs for about 400 for the whole car...
and this way you cna raise and lower the car as you see fit
Old Dec 21, 2002 | 09:35 AM
86 IROC's Avatar
23 views and only one response? I'm not looking to do a coil over conversion, my car is simply too low right now and I am afraid of bashing up my Hooker LT's on bad roads. Someone out there has had to have expirmented with different springs before. I'd really like to have some guidance before I go buy 10 different sets of springs.
Old Dec 21, 2002 | 03:42 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
86-up, stock level I springs are 350lbs in the front, level III WS6 springs are 548lbs in the front.
Old Dec 22, 2002 | 06:11 PM
86 IROC's Avatar
Justin, thanks for the reply. I appreciate it.
Old Dec 25, 2002 | 02:08 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
you can get new spring isolators from gm for about $5 each and they will raise your ride height about an inch from what i hear
Old Dec 25, 2002 | 03:25 PM
86 IROC's Avatar
Thanks for the reply, I think I'll try that first... it would be a bitch to toss the front Eiabach's after I paid $209 for a full set - then only end up using two of them. I'm almost wondering if the front end shop that installed my front coils tossed those spring isolators when they did the install. The ride height w/ the Eiabachs vs. my worn stock springs was over 2" lower. The rear Eiabach's didn't seem to lower the rear any. My buddy has Jamex springs on his 91' RS and the nose of his car is very low too, I wonder if that's his problem too.
MrPackstin
Oct 25, 2017 08:09 PM
92projectcamaro
Dec 8, 2015 12:25 AM
tcflint
Sep 27, 2015 05:58 PM
Dragonsys
Sep 25, 2015 03:51 PM
