Does anyone make a Manual Brake Conversion?
Old Dec 23, 2002 | 06:41 PM
92camaro's Avatar
Does anyone make a conversion to swap from power brakes to manual brakes. Just looking at saving a few pounds off the car since my power brakes don't work anyways.
Old Dec 23, 2002 | 07:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There are a few kits out there but none are a direct bolt-in. Some modifications are required. Converting to manual brakes only shaves off 5 pounds at the most. The booster doesn't weigh very much.
I made my own kit. I used a manual master cylinder from an S10. Relocate the brake lines to the other side of the master cylinder (f-body has the lines on the engine side). Fabricated my own mount to the firewall and fabricated a new pushrod. A new hole needs to be drilled in the brake pedel 1" higher for a straight line push and increased mechanical advantage.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
stalkier
Aug 13, 2015 12:59 PM
