The quest for traction.
Old Dec 29, 2002 | 09:04 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Ok, here is my curent list of upgrades for more traction. Shold I use anything else?
Alsont SFC's bolted in then welded
LCA's
LCA RLB will bolt ins hold up?
PHB
energy susp TA bush
New posi
Oh and a TA diff cover, and the brave kit to help the 10 bolt
I know tires are a definate plus, but im lookin to get some rims in the late summer, so i can re-use the stockers for a set of drag radials.
Old Dec 29, 2002 | 09:05 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
BTW this is for the 91 in my sig
Old Dec 29, 2002 | 11:46 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I think you should weld in your relocation brackets. Another item you may want to consider is an adjustable torque arm. I put the Spohn unit on and it improved my launch and braking.
-Schultzy
Old Dec 29, 2002 | 11:56 PM
MdFormula350's Avatar
looks like a great list...
Old Dec 30, 2002 | 11:43 PM
aklaim's Avatar
Def. want to weld in the relocation brackets. You want your rear nice and tight. Bolt in will give your rear the possibilty of movement which is your worst enemy when looking for traction.
1986Z28OWNER
Dec 13, 2015 10:19 PM
Reid Fleming
Oct 10, 2015 09:56 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
apie2546
Sep 5, 2015 07:40 PM
FlameRedMetallic
Sep 9, 2001 11:49 AM
