If S.S. Lift bars can be used on any sfcs
Old Dec 29, 2002 | 11:20 PM
jim71350's Avatar
Can Southside lift bars be used on any sfc's or do the have to be Southside ONLY
Old Dec 31, 2002 | 10:54 AM
bob8748's Avatar
Since no one is answering... I dont see where it would matter
Old Dec 31, 2002 | 11:23 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
the subframes work as a kit with the cross member and the lift bars without all componants you are out of luck.
the cross member is welded via the gussets supplied in the kit to the subframe connectors then the liftbars bolt to the crossmember and are then welded to the axle housing at a set pinion angle ***once in place your pinion angle can not be changed.
the installation of there kit knocked 2 tenths off my 60 time and that was with street cheapies
Old Dec 31, 2002 | 12:09 PM
jim71350's Avatar
I figured as much, Because there was a set on ebay real cheep(lift bars) and I guess that is why, Beacuse south side will not split up the kit, either you buy the whole kit or none of it. Just my luck!!! Thanks Guys
Old Dec 31, 2002 | 01:30 PM
bob8748's Avatar
What was the price of the liftbars? I bought the kit and now using ladder bars instead, I'm keeping the subfame connectors but they can be bought seperately from Summit for $157.39 and I have the lift bars, crossmember, gussets etc that I can part with.
Old Dec 31, 2002 | 06:01 PM
jim71350's Avatar
Sounds good! What are you looking to get for them? And what do you want to get rid of everything (minus the sfc's)?Or just the crossmember and gessets? Thanks Jim
Old Jan 1, 2003 | 02:33 PM
tyty49's Avatar
Car: 91 Maro & 97 Ram & 05 Roadstar
I'm intrested in the SFC's let me know or PM me!
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
