Help with my rear disk swap please!
Old Jan 2, 2003 | 02:30 PM
92GTA's Avatar
I'm rebuilding my rear end on my 92 GTA and while I'm at it I figure I may as well upgrade to rear disk brakes too.
Exactly what parts do I need for the swap aside from the SS brake lines?
First, how many splines are my axles? Do I need new axles? Are the brake calipers attached to the rear axles? What years will work on my car? I also plan on replacing all 4 rotors too so I don't need those either. What proportioning valve do I need? I assume I need PBR calipers for my year but where do I get those?
I'd like to get an exact list of everything I need so I can start looking for the stuff. I did a search and only found posts like "you need a proportioning valve" and "you need e-brake cable" but I want to know the details? Ok, proportioning valve, what's the GM P/N of the one that will work? Etc. I also read that stuff from the same exact year is the same so like if I got rear calipers from a 92 I wouldn't need a new proportioning valve because mine will work on drum or disk, is this true?
Thanks!
Old Jan 2, 2003 | 03:16 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Hey Alex,
The thread in the link below should answer your questions. Also talk to ANDYZ28 about the conversion. His CD-ROM also does a good job of showing the process. Are you planning to modify your present rear axle?
https://www.thirdgen.org/techbb2/sho...hreadid=139404
Hope this helps, I plan to change to rear discs too sometime after my front 1LE swap.
Old Jan 2, 2003 | 03:48 PM
92GTA's Avatar
Awesome, that helps ALLOT!
Thanks!
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
