Rear drum to Rear Disc convertion
I have a 91 Formula with rear drum and an open rear-end, Im going to switch the whole rear-end out of my 88 GTA with rear dics posi.
What all parts do I need to take off the the car and will it all bolt right up? (cables,brake hose)
I checked the parts catologs today and 88 and 91 have different brakes in the rear (pads, calipers,master cylinder).
Any help would be thankful
Peace
Peace
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
You might be better off to leave the '88 rear in the '88. Then get a posi drum rear in the ratio you desire, and convert it to the '90-'92 (PBR) rear disc brakes. They are much better than the pre '89 type rear disc brakes.
Thanx,ANDYZ28
Thanx,ANDYZ28
It does have the High Performance option RDB ( aluminum calipers) not sure if that is better but it is different in the parts catalog and alot more expensive $$$$.
Later
Later
Car: 1982 Z-28
An '88 should have Delco-Moraine cast iron calipers. Do you have a picture of the rear brakes? Or should I post one of a late model ('90-'92) rear disc brake setup for you to compare it to?
Thanx,ANDYZ28
Thanx,ANDYZ28
Car: 1987 Trans Am
Thanx,ANDYZ28
Thanx,ANDYZ28
Car: 1982 Z-28
Here is what is included in the drum to disc rear axle conversion kit;
1) New PBR loaded calipers.
2) New rotors.
3) New stainless steel prebent hardlines.
4) New "Earls" stainless steel flex lines.
5) New parking brake cables for your application.
6) New axle seals (you might as well replace them while you are in there) so I include them too
7) Special axle housing adapters to duplicate the original disc brake housings.
8) Shim templates to precisely locate the new mounting holes in the axle housing flange. They are also used to adjust the backing plate out from the axle housing. These have been discontinued by GM for a long time, so I have developed my own improved design.
9) New brake line/hose mounting brakets. These are also unavailable from GM.
10) New drill bits to modify the axle flange to the disc brake type.
11) Parking brake cable guides to keep the parking brake cables from rubbing against the axle housing.
12) Posi gear oil.
13) Tube of silicone to reseal the rear cover.
14) All of the various clips, bolts, and other fasteners to complete the job.
15) And best of all, I even include the correct GM combination (proporioning) valve for your application.
16) I also include the "ANDYZ28 1LE Plus CD ROM" Free!
All for $731.00 plus shipping.
Thanx,ANDYZ28
2) New rotors.
12) Posi gear oil.
Thanx,ANDYZ28
Andy, those are the calipers I have. My wagner catolag at work list those calipers on the 88's also, its listed as an high performace option.
So I shouldnt have any problems doing the swap??
Thanks for the pic..
Peace
Peace
Car: Yes...
Transmission: See "Engine"...
Peace
Peace
I did the same conversion.. The easyest way of doing it is leaving all the brake hoses on the rear and opening the joint thats in the front end of the well on the drivers side. eazy to find. the just swap the new rear in. take the brake balancer from the parted car if possible. if not you'll have to mod your old one. otherwise you won't have enough brake force at the rear of the car. drum braked cars use a 70/30 brake balace whilst the 4 disc cars use a 50/50 balance. the brake master cylindar is also 0.05" bigger on a disc car but i didn't get any problems with that. only the brake balace.
and yes it will bolt up. take the brake master cylindar and brake balancer if you can. don't take anything off the rear(brakes). just open to joint to the car and you'll be fine. at least i was.
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
If ur 88 has the rear pbr's i would just drop it in all you should need is the p valve.Im going to convert my pre 89 rear disc to the pbr's im waiting on my parts from andy
. If ne1 knows where i can get a new rear cover for a 9bolt that would help and the rubber plug.
. If ne1 knows where i can get a new rear cover for a 9bolt that would help and the rubber plug. Senior Member
Car: 92 RS 25th Anniversary
Engine: 350 L98 w/Vortec Heads
Transmission: 700 R4
My dad is a Heavyline Mechanic for GM and I asked him about doing this to my car. He told me I was better off finding a rear end off a 91 or 92 and bolting it up to my car. He said I would save alot of time and it is much easier to do! Plus you will have a posi!!!!!!!!! I have not started looking for one but I was planning to hit some junk yards. Finding a junked 91 or 92 Z is not easy. Does anyone know were I could find one in California!
Car: 83 Z28
Engine: 400sb
while were on the subject of the 9 bolt
anyone have any idea where i can get the e brake spring bracket for the rear caliper i have the counter weight and spring i just need the bracket that mounts to the caliper any info would be appreciated
RE Drum to Disk
So if i have an 86 Iroc with 3.23 gears and drums, can i swap my drum to disk? Or do i have to go out and buy a rearend that originally had disks on it. I wanted to just remove the drums and bolt up the disk. My intentions are to remove the carrier and put a SLP posi and change out the axles with 28 spline and bolt up the disk brake harware and call it done. Will that be possible or is there more to it than that?
Car: Yes...
Re: RE Drum to Disk
It us 9 bolt owners that are slightly challenged in doing this upgrade. The 9 bolt 1LE backing plates are long gone. The only option for us is Baer or custom work. Based on that, I'm considering going with the LS1 rear disc upgrade.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I just put a new complete LS1 rear on my 86 Trans Am so now I have a complete LT1 rear with disc brakes sitting around. I want to put those brakes on my 88 Formula and get rid of the drums.
I can't put that rear on the car since the 4.10's are shattered.
Will this be a plug and play conversion. I don't want to have the car down too long since it is my daily driver.
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
the 88 firebirds did too have pbrs I have said this on so many posts it is sick that no one listens! the ones on my car are from an 88 gta. it was not a 1le and it cam that way new. some 88s even that car had the vats key system if people would look these things up instead of just guessing there would be alot less missinformation on these boards
yeh i would want the pbrs zepher the ta rear wouldnt be right for the 88 they use a different master cylinder and i dont like them neway that what i did on my rs and im goin to the pbr's now its a pain. All you would have to change is ur prop valve to a 88 with the 4-wheel disc.
A buddy of mine wants to sell me a 89 Rear end with posi and the brake setup that is on a 91 and 92 Z! This rear end was of a Formula and I want to put it in my 92 RS which does not have posi and has drums on it! WHAT WILL I NEED AND WHAT WILL I NEED TO DO? I got the jist of it by reading threw the thread but I want to make sure it will work on my application............
My dad will help me do it but he is not sure what the exact differences are between the 2 setups..................
