Wrecked Car Need Help
Old Jan 3, 2003 | 10:25 AM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
The previous owner of my car ran it into a ditch and parked the car. Two years later I bought it off of him for $200 and a go kart motor and drove it home. There is some vibrations and heavy pull to the right. I know this is because the right side front wheel is almost an inch back compared to the other side and the toe is all off. We also thought there could've been flat spots on the tires from sitting for 2 years in a barn. But then today I jacked the back up and put it in gear and it seems a have an axel or rim bent too. I am getting ready to chain the car to a tree and put a come-along on the right front control arm and try to pull that foward but have no idea what to do for the rest of the probs...So any suggestions on what to fix and or anything else that could be wrong.
Old Jan 3, 2003 | 10:52 AM
ede's Avatar
ede
you'll move the car before you make any bent parts straight. best bet would be to tie the car down to some anchors and then pull it or better yet to use a jack. also you might want to look at what is actually bent and maybe replace it.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
