rear disc brakes?
Old Jan 11, 2003 | 12:44 PM
600_dollars's Avatar
rear disc brakes?
i have 84 trans am .. now correct me if i am wrong.. but the 84's had drums?...
My car has discs / disc pads... ? .. no drums?
Old Jan 11, 2003 | 01:35 PM
MdFormula350's Avatar
some one could of swapped in a different rear end..
did you run your rpo codes yet?
https://www.thirdgen.org/cgi-bin/rpo/index
Old Jan 12, 2003 | 12:03 PM
Steve86TA's Avatar
Car: To many to list
Your car very well could have had disc.Its not that uncommon for an 84 to have a disc rear
Old Jan 12, 2003 | 09:48 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
It just depends. It is possible to have gotten a rear disc setup. It just depends on how the car came. It was an option, not standard.
Old Jan 13, 2003 | 08:41 PM
oh i didnt have any idea that american cars could have had a rear disk at that time ..
Old Jan 14, 2003 | 05:24 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
they were outlawed til '85 lol, just kiddin
i saw an early 70s lincoln in a boneyard with a disk rear and i'm sure other american cars had them long before
Old Jan 14, 2003 | 09:10 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
vettes had em in 65
Old Jan 15, 2003 | 01:00 AM
jeffs82z28's Avatar
My 82 Z has four wheel disc brakes.
Old Jan 17, 2003 | 10:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
84 Trans Am's with manual trannies and engine code "G" got 4-wheel disc's... I know... I pulled a disc axle out of an '84 trans am.
The good news is your axle is also a 3.73 with a posi!
The bad news is the posi is actually an Eaton gov-lock locker. Do a Search on this board for Eaton gov-lock.. they're a bad design, and can fail. Mine blew up; now I'm back on a junkyard rear drum axle.
Bad news #2? Well your rear discs were recalled. Yep, 82-88 rear discs had a recall out on 'em. Since you've got a manual trans (right?), you can drive into a GM dealership, they can run the VIN, and find out if the recall kit was put onto your car. If it wasn't, they're supposed to do it for free. (It's a SAFETY recall, doesn't expire.) I fought this problem for a long time when I did the swap, find out about it here: https://www.thirdgen.org/techbb2/sho...postid=1098527 I just pushed this message to the top, in case anyone else needs this... don't want any 82-88 owners killing themselves (or spending $1000's in brake work) when a $50 kit will fix it all!
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
