question on spohn suspension stuff
Old Jan 14, 2003 | 06:32 PM
Trent257's Avatar
im looking to buy the adjustable lca's and adj. panhard bar
whats the difference between mild steel and chrome moly, is it worth the 40$ and 20$
Old Jan 14, 2003 | 06:58 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Well it is lighter and stronger then normal steel...I'm not sure how much of a difference though from the two. I have the chromoly versions of both products and they are great products. THeir both lighter then the stock versions and way way stronger.
Old Jan 14, 2003 | 07:13 PM
Z28DJP1987's Avatar
For your application the regular steel and non-adjustable LCA's &
Pandard bar would be a better choice. My opinion.
Old Jan 14, 2003 | 07:14 PM
CaysE's Avatar
if you have the cash, go with chrome moly
Old Jan 14, 2003 | 09:24 PM
REVLIMIT's Avatar
Engine: Built L98
well I think you should atleast get the adjustible panhard bar chromoly or not. SInce your car is dropped the rear end is probably alittle off to one side. In my opinion...if your not gonna buy the best...dont buy anything at all. I mean its only like $20 O_o
Old Jan 15, 2003 | 01:34 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
I agree with Revlimit, if your car is lowered at all you definitely want the adjustable panhard bar.
Old Jan 15, 2003 | 04:42 PM
aklaim's Avatar
I would just assume that everyobdy should buy adjustable parts in the first place. No sense in buying non-adjustable panhard and then lowering your car 6 months down the road and realizing you now need an adjustable one. Buy it once and buy it right. Buy the adjustable panhard, adjustable lca's, adjustable wonderbar. This way as mods pile up you will be able to fine tune your cars suspension. Just how I see it......
Old Jan 16, 2003 | 10:23 PM
CaysE's Avatar
I'm kinda unsure why you would need an adjustable wonderbar for ANY mods. Any examples?
Frozer!!!
Jan 19, 2024 04:55 PM
lt1z350
Aug 28, 2015 05:57 AM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
