brake probs
Old Jan 23, 2003 | 01:08 PM
camaro_1983_383's Avatar
brake probs
sometimes when i hit the brakes, the front of my car shakes back and forth pretty bad. im guessing that my front discs are warped. i read somewhere that they can warp pretty easily when braking hard around corners. i tend to do that alot because i live in the mountains where there is alot of downhill cutbacks.
Old Jan 25, 2003 | 10:14 AM
MdFormula350's Avatar
did you actually look at the rotors? just pull the front wheels off and look for grooves in them or anything else that doesnt look right.
Old Jan 25, 2003 | 10:27 AM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Do you mean it pulls to one side or the other. When mine did that, I changed the front brake hoses (rubber part connecting hard line to caliper) and it solved that problem.
Old Jan 29, 2003 | 07:47 PM
Dans_Zed's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3.73 posi
It does sound like warped discs. You would have a shaking steering wheel only when on the brakes. Keep in mind that and worn steering or suspension bushings or links will only amplify such a defect.
You should also take a serious and close look at your steering and suspension components. Most common are worn tie rods, centerlink and/or pitman arm. Last but certainly not least check for worn or mal-adjusted wheel bearings.
Old Feb 4, 2003 | 11:42 AM
yeah, the steering wheel shakes alot. thanks for the input. ill will check it out.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
89 formula TPI
Sep 8, 2015 08:00 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
