Brake fitting question
Old Jan 23, 2003 | 02:32 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Hey all I am thinking of swapping a 4gen Disc rear into my Drum Brake 3rd gen. I know it will all bolt up in the rear. My question is what needs changed up front and what fitting do I need to change to get the brake lines from the drums to bolt on to the disc.
Brian Felts
Old Jan 23, 2003 | 03:15 PM
aklaim's Avatar
Are you swapping in the whole rear or just the disc setup? Form the sound of it, it sounds like you plan on doing the whole rear. In that case it will bolt right in and conect to the existing lines you have.
Old Jan 23, 2003 | 06:34 PM
Yeah its going to one colplete swap....one out and the other bolt right in. I was concerned about the fitting from the drum brake not screwing in to the disc calipers.
Brian
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
