4th Gen to 3rd Gen Wheel Swap ???
Old Feb 6, 2003 | 01:16 PM
modern_master's Avatar
I bought a set of 4th Gen wheels like the ones pictured below but the front ones wont clear the tie rod ends on my '86 IROC. Is there a remedy for this? Has anyone else ran into this problem?
Old Feb 6, 2003 | 01:54 PM
aklaim's Avatar
Salad shooters......my 2nd favorite 4th gen wheel. And yes there is a remedy for your problem. Wheel spacers. Search for 4th gen wheel spacers on this board and you'll find out where to get them from. Im pretty sure you need 2.25" spacers for the front.
Old Feb 6, 2003 | 11:35 PM
Kandied91z's Avatar
what part of the wheel actually hits?
i just got done fitting 18x9.5 275's with a 2.25 adapter and had no issues whatsoever. the recommended was 2.75 which i will eventually go with in order to clear the new suspension but all stock considered it wasn't a problem.
i'd like to know how your hitting or if it's just because i'm using a 18 that give me the room?
Old Feb 7, 2003 | 09:28 AM
On the inside of the wheel just where it begins to turn out toward the bead. The Tie Rod End sticks out just far enough to prevent the wheel from going all the way on. They are 16"s so I'm sure 17"s or 18"s would work. What kind of money would I be looking at for spacers?
Old Feb 7, 2003 | 11:32 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
probably more than what u paid for the wheels.
Old Feb 7, 2003 | 11:35 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
http://www.skulte.com/ for adapters, $150.
you absolutely need them because even if you did get them on, the wheel would sit so far into the fender you won't be able to turn them because they'd hit the inside of the fender
Old Feb 7, 2003 | 12:19 PM
Kandied91z's Avatar
i had to pay 350 for my adapters....
check with andris he'll know what to do!
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
