LCA relocating brackets
I should be receving mine soon,, hopefully, but I need to find someone to weld them in for me.
Want I want is a few pics. of some installed so I can show them how they go in.
What do you think would be a fair price to pay to have this done?
And I can't do a serch now so ,,HELP!!
Thanks.
Thanks.
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
heres a pic. that someone on the board posted. I saved it so i know how to install when get'em.
He'll probably jump in here and help ya out. he's a great help.
Spohn's up there! he's a sponsor...I think there $65.....
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
I opted for BMR bolt-on units and planned to weld them even before I bought them. Why? I felt they offered greater strength, safety and stability. Notice the extra bracket that runs to the shock mount and welded.
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
If you do not like to measure I would get the BMR ones. It took alot of measuring to get the Spohn one exactly right
Car: 91 GTA
Engine: 377ci
I also ended up having to change my shocks. They were brand new racetecs. I know they are not the greatest, but they really did not dampen the axle afterwards.
Car: 91 GTA
Engine: 377ci
I wanted to make sure all I was doing was lowering the mounting point not changing the location of the axle to the chassis or the angle of the pinion. To do this I used a piece of all thread to go through the chassis mounting point. I then attached an L bracket I made that came out the same distance as the axle hub. I then measured from this bracket to the center of the axle. I also measured from the bump stop mount to the pad the bump stop hits on the axle. I made sure these measurements were within a 16th of what they were when the LCA's were in the stock mounting point. You probably would not have to be as critical if you have adjustable LCA's.
yeah Im pretty sure they are.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Originally posted by RMK
Wishmaster,
Is that Spohn brackets in that pic you posted?
Wishmaster,
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Car: '87 Chev
Engine: 60*V6
Re: $$$$$
Originally posted by 330hp_91RS
How much for the BMR ones and where can I get them??
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Car: 91 GTA
Engine: 377ci
I wonder what it would take to get moser to produce an axle that already has brackets with lower mounting holes. I will soon be upgrading my rear end and I do not feel like performing the task of welding on new location brackets AGAIN. The axle housing are already custom made aren't they? Most the guys using these rear ends will need this provision anyway will they not?
Car: 91' RS
Engine: Built 355
Dammn!
110$ BUCKS FOR THOSE FREAKIN' THINGS! Wheew! Geeez, the lakewood LCA's I was planning on getting cost less than that!
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
It looks like those relocation brackets are just a piece of 3/16 ( possibly 1/4) steel plate ....with to bends ...and a couple of holes ..........they want WHAT ?!?!?!?!?!
rip offfffffffff .........................it's not like we are driveing imports here ( raped on parts ....for NOOOOOO reason )
I think I will make my own ........I'll post a pic of a diagram ......I don't see why a shop wouldn't fabricate this for you for nothing
Car: 91 Red Sled
Car: '87 Chev
Engine: 60*V6
Originally posted by JPrevost
I would bite my lip if I were you. First off they aren't just bent steel. They have holes drilled in the correct places, come with welded in spacer on the inside of the bracket and new bolts/washers. Considering they're cut and bent, and welded, I would dare to find ANYONE that can have them made for the price Spohn sells his at.
Also note that the BMR units are powder coated for their price. So there - again
... lets see you build your own and then send them to get powdercoated all for that price or under in time and materials.It feels great to vent sometimes
Its late so I'll shut up now.
I wasn't aware that you had to have spacers welded into the WELD ON ones, untill I got them. There in there now but It's something that wasn't even in the so called directions that came with them.
Car: 91 Red Sled
Car: 91' Z28 Vert
Engine: 305TPI
Transmission: 5 speed
Excuse me for being ignorant, but what is the purpose for the relocation brackets? I'm sure it improves the suspension, but how exactly???
The LCARB's improve traction by changing the way that the force applied by the tires pushing the car forward affects the lower control arms and thus traction. Here is a quick sketch to describe what it does.
Ric
Ric
By the way I made my brackets and will NEVER DO THAT AGAIN.
Although I am quite happy with how they turned out they took me 6 hours of flat out working to make them. 6 hours times 20$/hour pluss material totals up to about $200 cdn or about $150USD. I could have worked overtime instead purchased the Spohn brackets and still had money left over for beer and pizza while me and my buddys installed em. Doh
Here's a pic of what I made anyway
Don't try making these things the Spohn bracket is a fabulous deal.
Ric
Ric
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
Quick Q..
Got a dumb question. After you install the relocation brackets does this affect your wheel alignment in anyway?
Oh..two more dumb questions.. after reading the posts Im somewhat confused.
1- I understand that you CAN weld the relocation brackets AFTER you bolt them in but do you HAVE to do any welding after you installed the brackets??
2- Do all LCA's fit the relocation brackets? Because I have Hotchkis LCA's and they are "physically" bigger than other LCA's. (I think they are bigger anyway)
And yes..Hotchkis products are a good amount of money compared to Lakewood. I opted for Hotchkis because I thought their LCA's and panhard rod looked "beefy"
TIA
Dan
TIA
Dan
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I had mine done at a welding shop along with the sfcs. They charged me 140-160 for everything. Theres instructions with the spohn brackets. After you have the brackets welded on your ready to go. Might want to prime and paint them.
I don't think the LCAs would be bigger widths from different companies due to that fact if they are how would someone how is just using stock mounts use that lca? It would cut into a companies sale market, since a smaller number of people could actually mount them up.
I agree that if anyone is going to get these then they should get the Spohn ones.
First of all they are cheaper. $65.00 compared to $69.95
And 2nd the BMR weld in ones don't have the spacers welded into the inside of them so there not complete and you'r going to have to have some made if you dont have the meens to do it yourself. I dont think you would want to fill that gap with washers, so thats is going to cost you more money.
I got mine as a package deal from Thunder racing and didn't know that at the time so I had to make my own spacers.
I just think that BMR should say that somewere so people will know, and I have found nowere that tells people that, or they should make them with the spacers like spohn dose,, or,, they should lower there price.
Just something I thought everyone should know.
does anyone know if the BMR bolt ins will work with my Dana 44 rear??
will they make that much of a differance at the track or on the street ??
Does anyone have time slips to prove the effectiveness of the brackets??
Any hard performance numbers would be appreciated. Thanks
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
[IMG]
[IMG]
Car: 91' RS
Engine: Built 355
Gosh darn-it!
Originally posted by Dyno Don
Like the man said....for eaze of installation...get the BMR's. You will thank us later
Dyno Don...How much did you pay for yours?
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
There are always GPs on BMR stuff. Check out some of the 4th gen boards. I got my powercoated black BMR bolt ins shipped for $100.
I'm sorry, but can someone please tell me what these "LCA Relocation Brackets" are for? I've only heard that they need to be used when you lower the car???? I plan on the Eebach 1" lowering springs soon, will I need these brackets? O.K., I need to know what their purpose is, what will happen if I don't use them, where exactly they get installed, and what gets attached to them. Thanks all! -89IRO
Ummmmmmm, O.K., that diagram is nice, it tells what they do. I would like to know if these LCA relocation brackets are to be used when lowering the car like I described?? I also heard it should be used when you install SFCs, but that one doesn't make sense like the lowering of the car does. Also, with these new brackets, can I use my stock LCAs? Will the fit be fine with the new brackets? BUT, if I wanted to upgrade to new spohn LCAs, is the length the same as stock?
Some other questions- as far as the springs go, do they need to be compressed in order to take the stock ones out? Also, I know the SFCs get installed in a muffler shop, but would I just take the car to like a suspension shop or to have all this crap done? I mean I don't really know of any suspension shops around here (so. cal), I just know there are places to lift a big truck but I don't know if they would do all this stuff. Thanks guys. -89IRO
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
When you lower your car the angle of your LCAs alters for the worse. What the brackets do is correct the angle of the LCA so that more weight is transfered down onto the pavement. The brackets will also help to eliminate wheel hop that is very often a by-product from when you lower your car.
Robert
Robert
