Sway Bar Question
Old Feb 10, 2003 | 10:51 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
Sway Bar Question
I just picked up a set of aftermarket high performance sway bars for my camaro. They are made by Koni and come with poly bushings and end links.
Now the front is 1 1/4" and the rear is 7/8" so that works out to 31.75mm and 22.2mm. The thing is that the front bar is solid and not hollow like the 34mm Iroc or 36mm WS6 bar, so what I would like to know is which bars would be more rigid? This front bar weighs around 23 pounds or so.
Old Feb 10, 2003 | 11:13 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
I have Spohn solid bar combo 34mm/25mm (34mm =1 5/16" / 25mm = 1") on my V6and the *** end is slightly loose now after installing his subframe connecters. The inside rears are lifting a bit too much now with the more rigid chassis. I'm going to opt for a smaller rear bar like your solid 7/8" to keep the rear planted. Also remember, I have a lightweight V6 up front with 800Lb springs and I'm still lifting the rear. This would be way worst with a heavier V8 car that I believe stock runs about 650-700 lb springs. If I had a V8 in MY car the way it is setup I would opt for a 36mm Solid front bar if I could find one (otherwise go up a bit in spring rate with the 34mm- probably as high as 1100Lb springs- Can you say hard ride on the street) and I would buy the 7/8"solid for the rear. 25mm solid (1") is too big for the rear of these cars under any circumstance.
Old Feb 10, 2003 | 11:31 AM
Car: 1992 Camaro
Engine: 350 miniram
Thanks for the reply
I also was told that the 25mm rear bar I had was going to be to big so thats the main reason I bought these Koni sway bars since it had the smaller rear bar. I have a 36mm WS6 front bar for my car as well, I was just wondering would would be more rigid a hollow 36mm or this solid 32mm Koni bar.
Old Feb 10, 2003 | 03:10 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I've been told that the stock 36mm bars are better than any aftermarket bar you can buy, and that it is also a good idea to keep the bars matched; 36mm with 24mm, etc. Again, I don't know this from personal experience, it's just something I've read.
Old Feb 11, 2003 | 12:08 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
My guess is that they will be very close in torsion. I would lean towards the 32mm solid being more stiff though but it really depends on the wall thickness of tube used on the 36mm hollow bar.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
