Thirdgen outhandling a Ferarri...CHP Article
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Originally posted by Pat Hall
With GM constantly trying to save money on production costs, you're trying to tell me they had different control arms on the Z/28's? All the control arm does is hold the coil spring in and attach the lower spindle. Why the hell would there be any need for a different design between the two models? As far as different rubber in the bushings, that's a total riot! Energy suspension wouldn't be selling poly bushings like hotcakes if GM had actually designed their bushings for long life, durability, and performance!
Next you're probably gonna try to convince everyone that the Z/28 got "special" sway bar end links that don't rot, become as thin as a pencil, and break just like the rest of the camaros on planet earth because some yahoo salesman at the local chevy dealership said so right? I've yanked lots of parts off of Z/28's and RS's, and the only differences I noticed in the suspension parts were bigger sway bars and different spring ID tags. The rest of the pieces are the standard issue, stamp them out cheaply by the thousands chassis pieces.
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Those interested in the best handling for their third gens. should check the web for track days offered for both Hotchkis and Global West Customers. I know that the Global West people offer tech support on these track days and can really get you dialed in. It is best to have the knowledge to optimize your suspension, especially if it is adjustable. Steve Spohn might have track days also. I would check. He is the king of customer support and I would not be surprised if he offers this to his customers.
I watched the Atlanta Runoffs last year and of the top three finishers in C sedan, two were third gen.s (1st and 3rd), one was a 4th gen. (second) and best of all....no Mustangs finished on the podium. Gettie Up Lil' Ponies, Gettie Up!
i have that article i always use it to back up how good our cars handle. i got the hotchkis springs my rear end looks centered fine.Thats car had the 36mm front bar they just replaced the rear with a 1" bar .
Originally posted by 25THRSS
sweet, i thought the z had a wonderbar or something like that, but guess not, makes me feel even better about my little rs
BretD 88GTA, i belive my sway bars did also come with poly bushings... my dad has owned the car since new, and i asked if he ever got the front or rear rebuilt with poly busings.. he said never... the bushings are 16 yrs old, there still red and look brand new... saved me some money when i threw on the 36/24mm sway bars...
Car: `86 SS / `87 SS
oh and there are no 34mm sway bars that are hollow..the only ones that are hollow is the 36 that came on the 1le and some WS6 cars...
The 34mm and 36mm bars were hollow. I've had one of each in hand all at the same time. The weight difference says the 34 is hollow. On a friends 1991 low option 5.0L/M5 Z28, it had a 34mm bar. On his high option 5.7/A4 Z28 it had the 36mm bar.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
GM will do anything to save a buck or two when it comes to production costs.
Why do you think I just finished spending a fortune on all the parts for the 1LE brake upgrade when it should have been the standard brakes on all the cars! With GM constantly trying to save money on production costs, you're trying to tell me they had different control arms on the Z/28's? All the control arm does is hold the coil spring in and attach the lower spindle. Why the hell would there be any need for a different design between the two models? As far as different rubber in the bushings, that's a total riot! Energy suspension wouldn't be selling poly bushings like hotcakes if GM had actually designed their bushings for long life, durability, and performance!
GM DID put different bushings in a-arms. A 1LE is one example but not the only example. I've already seen, wrenched on, poked and prodded a-arm and body mount bushings (non thirdgen) with harder rubber than other ones when a single durometer of rubber would have done.
Once again, this would've cost them more money to produce two different styles of bushings. Next you're probably gonna try to convince everyone that the Z/28 got "special" sway bar end links that don't rot, become as thin as a pencil, and break just like the rest of the camaros on planet earth because some yahoo salesman at the local chevy dealership said so right?
Originally posted by Dewey316
i thought that the factory polly bushings were white/cream colored, but then again i have been at work for 6 hours now and my brain is not functioning at 100%
Car: '88 IROCZ
Engine: 363 Vortec w/Miniram
Transmission: built 700r4
stock IROC suspension is good for over a G of cornering with Hoosier Road Race tires. I've never driven a ferrari, but I'm sure many of you iroc people running good performance tires have made hard turns at 50+ MPH with all the stability of a train on rails. I was never for the road race scene but I see a lot of 3rd gens tearing that arena up, more so than the drags actually. LS1s don't have **** on 3rd gens in the twisties...
Car: 1990 Camaro RS
i like that plate dean
i'm thinking about getting 'ON RALZ' for mine (only 6char+a space in Oregon) thats if i dont' get 'BLWN RS' (need a blower for that one though
btw, when is the $500 challange going to happen
i'd like to drive down there and watch that, maybe if you loan me your tires, i'd run too
)btw, when is the $500 challange going to happen
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
I tried for OnRails and several variations of it, but So.Cal is the hotrod capital and hard to get good plates anymore.
$500 Challange- never got a taker and Mods got on my butt for rousting the guy alittle- oh well- I had my fun.
I am actually going out to the garare right now to tear down the car and go through it- New hiems everywhere, gotta pull the tranny- Front pump seal showing moisture only after 8 months (bad seal- **** happens)- going to pop in an ACPT carbon shaft also (something I have want to change awhile back but never got to then. Pulling tranny so I figure nows a good time (I hate working on cars if I don't have to -I'm getting old).
Have a good day
SO many people under estimate the IROC's handling till they get a ride. I let a kid who owns a late model Nissan 240SX with quite a few suspension mods and who has been auto-xing for a while ride shotty with me around the course and he said," "Holy $hit! I have a whole new respect for this car...this thing stays so flat! It has no body roll what-so-ever!"
I get that response pretty much every time I give someone a ride...they expect it just to pull hard in a straight line and blow in the corners, but it's just the opposite...
Terrell351
Jun 13, 2021 01:13 PM
