rear sway bar size?
Old Feb 13, 2003 | 03:52 AM
rubber_lee's Avatar
rear sway bar size?
Search is down and I need help. What size bushings are on my rear stock sway bar. 305 tbi if it helps. I plan to buy from pst
Old Feb 13, 2003 | 06:12 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
your best bet is to measure.
Old Feb 15, 2003 | 11:42 PM
rubber_lee's Avatar
thanks. I used an adj. wrench and found out i should use a bigger sway bar. Im looking for a 1le rear to match my 36mm front.
Old Feb 16, 2003 | 12:49 AM
MdFormula350's Avatar
yeah search ebay or the classifieds for the 24 mm rear sway bar...
Old Feb 16, 2003 | 01:41 AM
rubber_lee's Avatar
I found one on ebay that sells as 3/4 in thick, but localy one from a formula that I measured at 1inch, which should I go for? both will be around the same price.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
