Eibach sportlines...will I need camber kit??
Old Feb 25, 2003 | 02:18 PM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
Will I need a camber kit for the sportlines??? Or can I just align he wheels to stock specs and it will be fine. Those of you with sportlines, what did you do??
Old Feb 25, 2003 | 03:21 PM
82camaro's Avatar
Car: 82 camaro SC
Assuming your car isn't damaged in any way, drop springs won't require you to get a camber kit--you will have plenty of adjustment. The stock settings suck, even with the stock springs. With drop springs the stock specs are even worse. Do some searches on alignment specs...
Old Feb 25, 2003 | 04:34 PM
speed88's Avatar
Engine: 383
Thanks 82.
Old Feb 25, 2003 | 08:06 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
No you dont need a camber kit cause the camaro comes with a camber/caster kit from the factory. I'd say to allign it similar to the stock settings but with a little more negative camber and allite more positive caster.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Antips16
Oct 30, 2015 06:42 PM
jbates346
Oct 21, 2015 01:50 PM
gta_knight
Sep 23, 2015 04:59 PM
Chiknhawk
Sep 10, 2015 08:55 AM
