How to know if chassis is bad
Old Feb 25, 2003 | 07:50 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
How do I know if the chassis is bad/bent? What signs should I look for? My car has been in a accident before I bought it and I want to make sure the frame ain't screwed up.
Thanks,
Matt
Old Feb 25, 2003 | 09:33 PM
87daddyformula's Avatar
Car: Formula
Engine: 5.0L
Transmission: 700R-4
I would suggest having a unibody repair expert look at it. Other than that I really don't know...maybe listen for strange sounds when cornering hard.
Old Feb 25, 2003 | 09:39 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
You could also try having a friend follow you while you drive and watch the car for obvious signs of chassis problems, like dog tracking. Collision shop would be the best place for diagnosis.
Old Feb 25, 2003 | 10:51 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Set back and thrust angle (being positive or neg will cause dog tracking) alignment angles can clue you in to any problems. measure from the torque arm mounts in the rear cross chassis to the front subframe. Both diagonals should be the same length.
Old Feb 26, 2003 | 05:42 PM
Matto'85TA's Avatar
Whats "dog tracking"? I'm going to go to a body shop eventually, sooner if the chassis is screwed.
Thanks for the replies.
Matt
Old Feb 26, 2003 | 05:59 PM
No4NJunk's Avatar
Have you ever seen a car or truck (alot of vans have the problem) where the back was more to the right/left the the front going in a straight line?? That is dogtracking and its caused by an positive or negative thrust angle. Rear end collisions will cause this along with a misaligned rear if its independant. Solid rears can't be adjusted (toe & sometimes camber).
Old Feb 26, 2003 | 06:13 PM
Matto'85TA's Avatar
Thanks. Duh I should have known that. O well.
The car looks like the possibilty of front collision, particularly bthe driverside. My fenders don't line up with the doors. The strut tower also looks dented, sort like it was hammered out. I posted on the body board. Heres the link: https://www.thirdgen.org/techbb2/sho...hreadid=163403
Thanks again.
Matt
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Chad Speier
Sep 24, 2015 12:32 PM
64Chief
Sep 12, 2015 08:05 AM
buckshot63
Sep 10, 2015 09:15 AM
SG91camaro
Sep 5, 2015 10:27 PM
