Do I need to dissconnect my steering linkages to install Ball joints?
Old Feb 28, 2003 | 12:36 AM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Just wanted to know if I have to remove the spindles to replace the ball joints. I will be removing the A arms and installing new bushings, but I don't want, nor do I have the money for a pickle fork, I'd rather just push that stuff to the side to do the job. By the looks of it I think it's possible to do this but I'm not positive. Will this work, or do I have to remove it all? I'm a bit limited on tools.
Old Feb 28, 2003 | 08:18 AM
ede's Avatar
ede
you can rent one from autozone. if you can't find one you can loosen the nut untill the stud is fluch with the nut and hit the control arm where the ball joint is with a BFH and it'll pop out, might have to hit it a time or two but it will come loose. also works for tie rod ends.
Old Feb 28, 2003 | 08:52 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Do I need to dissconnect my steering linkages to install Ball joints?
You will have to separate the ball joint from the bottom of the spindle. Other then that the steering linkage and spindle can stay.
RBob.
Old Feb 28, 2003 | 05:57 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
here's how i did it:
https://www.thirdgen.org/techbb2/sho...hreadid=154669
btw, a pickle fork is only like $6 or you can do as mentioned earlier and rent one. all the places around here give you a full refund when you return the tool. you'll need to rent/loan a ball joint press anyway so you might as well just get a pickle fork or the two jaw ball joint seperator while you're at it.
Old Feb 28, 2003 | 06:48 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
and here's how do it w/o a press.
www.fl-thirdgen.org/balljointreplacement.html
Old Mar 1, 2003 | 05:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
mrr23, thanks for that link!!!
Old Mar 1, 2003 | 08:28 PM
mrr23's Avatar
Engine: 360 HSR
anytime
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Mar 22, 2019 09:39 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
MENINBLK
Aug 5, 2015 11:58 PM
NBrehm
Aug 5, 2015 07:57 PM
