front sits higher....
Car: 1985 Trans Am
Transmission: 5 Speed
the front sits higher after getting my alignment and front lower control arm bushings changed, is this right?...it feels very top heavy......
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
they probally let your suspension stretch out when they had it on the lift, give ti a while, it'll settle back down in a few days
Car: 1986 Firebird
Engine: 2.8 V6
If they torqued the front LCA bushing bolts down with the control arms hanging, they might've induced a preload into the bushing- the bushing wants to return the LCA to it's "hanging down" state, even though the car is pushing down on it. Those bolts are supposed to be tightened while the weight of the car is over the front wheels. Hopefully they tightened the bolts when the car was on a drive-on lift, and not a frame lift.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
With the front tires on ramps, loosen the A-arm bolts, hop on the fenders to push it all down, and tighten them back up.
Ed
Ed
Car: 89 Iroc-Z
will tighening them this way really have a huge effect? how long will it take for the arms to situate right. if it fixes itself over time i'm ok but if not, i better loosen and retighten too. i know i tighened mine when they were hanging.
I won't swear to it since I didn't do it, but it's been mentioned here. It'll take you a half hour max so I'd do it.
Ed
Ed
Street Lethal
Apr 30, 2019 12:14 PM
