front driver's side caliper
Old Mar 12, 2003 | 09:07 AM
panman79's Avatar
I don't believe the front driver's side caliper is releasing. My brake light is on in my intrument cluster. After driver for about 10 min. the left driver's side wheel well will start smoking.
This could only be the caliper causing this right? Thanks for help
Old Mar 12, 2003 | 02:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Brake light comes on either if the e-brake's up, or if there's unbalanced pressure (AIR!) in the lines between the front brake lines and the rear brake lines. Air must've gotten in that line somehow.
As to the smoking, it could either be the caliper, or a collapsed brake hose. Is it the original brake hose? For safety's sake, you should probably replace both at once... and then you'll have to bleed the system, which should get rid of any air. And again for safety's sake, you should probably replace both front brake hoses at the same time. You don't want to have one good unclogged, uncollapsed hose on the driver's side, and a ready-to-fail brake hose on the passenger side.
Old Mar 12, 2003 | 02:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably the brake hose. Those die alot and cause problems like that.
Old Mar 12, 2003 | 04:31 PM
panman79's Avatar
Thanks for the help. I replaced the caliper today, (10 bucks at autozone). It's not smoking anymore. Coming to a safe stop is good.
Old Mar 13, 2003 | 11:59 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
If it does it again, change out the hose.
Ed
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Aug 14, 2015 08:25 PM
wruiz
Aug 11, 2015 02:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
