front cross member
Old Mar 12, 2003 | 07:00 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
front cross member
Has anyone moved their front cross member from side to side. Looks like 6 bolts into the body frame and another 6 for the brackets on the front. Any suprises? I want to move it 1/4"
Old Mar 12, 2003 | 07:53 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
It won't work. There's 2 dowel pins on each side of the K member that locate it centered on the frame. Why do you want to do this anyway?
https://www.thirdgen.org/techbb2/att...postid=1055458
You can see them, they're in front of the spring pockets.
Old Mar 12, 2003 | 08:37 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Thanks for the info. I kind of thought there might be something like that. The few bolts I took out seemed to have slotted holes, maybe even body shop done. I think the car has been whacked before and the wheels sit different on one side than the other. You have to look close to notice it. It would be interesting to know if both those pins are still there. Funny thing is the car is one of the nicest driving cars I have ever had.
Old Mar 12, 2003 | 10:29 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Thanks for the info. I kind of thought there might be something like that. The few bolts I took out seemed to have slotted holes, maybe even body shop done. I think the car has been whacked before and the wheels sit different on one side than the other. You have to look close to notice it. Funny thing is the car is one of the nicest driving cars I have ever had.
Old Mar 13, 2003 | 02:04 AM
JERRYWHO's Avatar
Re: front cross member
Yes you can move it from side to side the pins only locate the K-member front to back in the car. The slots in the body are about 7/16 longer than the pins for side to side movement.
I had to move my PA K-member after install the K-member was to far to the driver side. The drivers header hit the steering shaft and all I did was unbolt and used a big screw driver to push it over now I have the same room for the drivers header.
When you move the K-member the camber will change on both sides (one more and one less camber ) also the steering wheel will move off center the toe and caster will stay the same.
If you need a better picture I can take better one.
Jerry
Old Mar 13, 2003 | 10:59 AM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Thanks Jerry
When I have the motor and suspension out I will give the move a try.
customblackbird
Aug 15, 2021 10:16 PM
Street Lethal
Apr 30, 2019 12:14 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
LT1Formula
Nov 16, 2015 01:13 PM
