What Grease ??
What Grease ??
I bought some of THIS grease when I bought all my new bushings and other goodies for my suspention upgrade and was wondering if it would be O.K. to use it for my new ball joints. Or should I use something else?
It says they use it for the entire chassis.
What do you think ??
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The SuperLube grease should be great on your front-end including your balljoints. It's compatible with other greases that may be present from earlier lube jobs. Plus the stuff is non-toxic.
I have a tube loaded in my grease gun and use it from all my suspension zerk fittings.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I use it on every grease fitting I have, including my ball joints. Steve said you can use it everywhere so I do. It's great stuff, and IMO better than Formula 5 lube that ES and others give you.
Ed
Ed
CarGuyDennis
137
Dec 6, 2016 11:02 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
Numbah-1
Sep 12, 2015 08:57 PM
