sway bar measurements, need help
Car: 1989 Chevrolet Camaro IROC-Z
Engine: 5.7L TPI
Transmission: WC T-5
I'm trying to measure up my sway bars for new bushings. Where is the proper place to measure the front bar?
If I measure the diameter right in the middle of the bar, I get 36mm on the caliper. If I measure right along side of the bushing, I am getting about 34mm? Which would be more accurate to measure bar diameter? (The rear bar appears to be 24mm at all points)
I was thinking the 34mm, but not sure. The bar appears to be hollow, as it has a hole near the end link (on the top) at each end. Was the 36mm the only hollow bar?
Also, what is the standard sleeve length. I measured 2 1/4 but the shortest I can find is 2 5/8. As I plan to lower the vehicle, will this be a problem.
My car is an 89 Iroc 350ci (FE2).
Axle/Gears: 3.45, 3.27, 3.27
Measure next to the bushing. Both the 34mm & 36mm GM bars were hollow.
Lon
Lon
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
See if you car is here. Looks like it could be either:
https://www.thirdgen.org/techbb2/sho...ight=questions
Ed
Ed
darwinprice
17
Oct 11, 2015 11:51 PM
