wheel bearing install question
Old Mar 21, 2003 | 10:30 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
after greasing my bearings, i put the castle nut back on finger tight and the hole for the cotter pin does not line up with a slot in the castle nut. should i back the nut off or tighten it past finger tight to get the hole to line up? tightening it would probably put about 5-10ft.lbs. on the nut
Old Mar 21, 2003 | 10:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Turn the rotor as you tighten it, to about 15 ft-lbs on the nut; then back it off; then tighten it to about 10 ft-lbs while spinning the rotor, then continue tightening it until the holes line up.
Vintageracer
Jan 10, 2020 05:33 PM
red90IROCls1
Aug 25, 2015 06:56 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
rsrmoore
Aug 7, 2015 08:44 PM
