What size are V6 RS sway bars?
Old Mar 23, 2003 | 09:37 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Car is a 91 Thanks
Old Mar 24, 2003 | 12:22 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Probably has a 34mm front; don't remember the rear... if you can get to the car, tighten down an open-ended adjustable wrench on the middle of each bar, then hold it against a ruler...
Old Mar 24, 2003 | 02:10 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
'87 RS 20th yr Calif Ed. V6 stock bar size - 32mm hollow front/23mm solid rear. Now with SFC's I run 34mm solid front/ 23mm stock rear bar. Before SFC's I ran 34mm solid front/ 25mm solid rear bar. Thats with 800# springs front/225# springs rear. (I believe stock spring rate on a V6 is about 550#front and 175#rear or there abouts). Alot of testing done with this car w/ different combos to get this balanced but its dialed perfectly for handling with the combo above.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
J0386
Oct 12, 2015 07:46 AM
Nervous2
Oct 8, 2015 10:53 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
92blue
Jun 15, 2002 03:07 PM
