Can you convert pre '89 rear disc brakes to '89+ rear discs??
Old Mar 24, 2003 | 12:30 AM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
If I find a rear end that's pre'89 is it possible and how hard is it to convert the brakes to '89+ parts? Does it make any difference (other then price) if it's a 9 or 10 bolt? I guess this question is pretty straight forward but feel free to give any advice that you feel is pertinent to this subject. Thanks.
Old Mar 24, 2003 | 01:23 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
They will bolt right up, as long as the brakes are off the same bolt diff.
Old Mar 24, 2003 | 09:19 AM
TwistedIROC's Avatar
The rear brakes from the 9 bolt unit will not fit, I know from experience. You will have to run brakes off o a 10 bolt on a 10 bolt.
Kyle
Old Mar 24, 2003 | 10:21 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The only difference between the 9 and 10 bolts should be the backing plates.
Old Mar 24, 2003 | 12:24 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yup. any parts for 9-bolts are very hard to come by.
Old Mar 24, 2003 | 03:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Now -that- is some cool information. They need different parking brake cables though, right? What's the advantage to 89-92 rear discs over 82-88, besides the "recall" of the 82-88's? Aren't those 89-up PBR calipers aluminum or something?
Old Mar 24, 2003 | 03:48 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes
Old Mar 24, 2003 | 03:49 PM
Car: 1988 IROC-Z
yup. you will need the parking brake cables as metioned for the full functionality.(i.e. u actually use the parking brake) to bolt them on you will need to change the backing plates and the hardlines on the rear end. yes they are aluminum. they look cool . the ebrake is a joke though.
Old Mar 24, 2003 | 08:07 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Aren't some of the fittings for the brakes on the 82-83 cars standard as opposed to metric on the newer ones.
Old Mar 24, 2003 | 09:03 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I adapted my pre-89 9-bolt disc brakes to my Dana 44 (which uses 89+ brakes). When switching between 9 and 10 bolt brakes and/or pre89 post89 brakes you'll have to swap out the backing plates. For me I had to drill new holes in my 9-bolt plates to fit the Dana 44's pattern although I'm almost positive the bolt pattern is the same on 10 bolts and 9 bolts.
Pulling out the axles (to swap backing plates) sounds scary at first but its actually pretty easy.....
Old Mar 24, 2003 | 09:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The Dana 44 and 10 bolt have the same bolt pattern. The 9 bolt is different.
Old Mar 24, 2003 | 10:08 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I'm sorry guys, I think I made my question confusing. I just wanted to know if you could swap pre '89 brake parts with '89+ brake parts. I didn't want to know if you could interchange 9 bolt and 10 bolt parts, only if you could swap parts from the newer style rears to the older regardless of whether you were doing 10 bolt new to 10 bolt old or 9 bolt new to 9 bolt old? Sorry for the confusion everyone.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
