installing a strut tower brace
Old Mar 25, 2003 | 10:27 PM
trace's Avatar
searched already & couldn't find answers...
i'm about to replace my tires and get an alignment, and thought this would be an appropriate time to add a STB? i want a 3 point, so which would you recommend for a 92 RS TBI? (and where is the best place to buy it online?) i'm leaning toward the Edelbrock for $129 from Summit. anyone know of a better deal?
now some questions about installation...
when you install a STB, might it be a good idea to jack the car up a bit behind the front wheels to take out some sag from high miles? i've noticed my doors close much better if it's jacked up just a little. (i'm talking like an inch or so of spring travel - no more)
and for the hardcore DIYers:
i'm pretty good with steel fabrication, and have done suspension stuff before - how many of you have made your own STBs and/or wonder bars? how much trouble were they?
TIA~ Trace
Old Mar 25, 2003 | 11:09 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I remember car craft installed on one their 88 Formula. Look around carcraft.com to see if they have it. I remember them saying be sure not to center it with the motor because it is not in the center of the engine compartment. And jacking the car up seems like a good idea.
Old Mar 26, 2003 | 02:40 AM
sllt1776's Avatar
Car: 89 Iroc-Z
i think the edelbrock would be good. there aren't too many choices for 3 points and tbi. i would suggest against jacking it up. kinda like the sfc's. you want the car to be in a settle state or you will always have a load on the stb. this can't be good.
Old Mar 26, 2003 | 12:33 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
The edelbrock one is the best. Biggest and best built. From what I've been told and red, you leave your car loaded, NOT jacked up, installing both subframes and a STB. You're doors might close better, but you're going to throw your chassis out of whack.... not to mention, your doors wont close better with a jacked up rear when you put the STB on. The STB is just that STRUT TOWER BRACE.... it only affects the front struts from flex.
Old Mar 26, 2003 | 03:42 PM
uk89camaro's Avatar
I would guess that installing the STB with the load off the front would only allow a permanant understeer.. My edelbrock 3 point gave me great results, fitted on the ground.
Old Mar 26, 2003 | 04:07 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
just an option I got my 2 point carb/tbi from Flatout performance......it goes for about $75 bucks unpainted.
It's a very strong and relitevly light.
http://www.supersportperformance.com/index.htm
Old Mar 26, 2003 | 10:29 PM
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
Made my own, wasn't hard at all. Right now it's a two-point, thinking about turning it into a three- or four-point.
Old Mar 29, 2003 | 05:10 PM
trace's Avatar
well, i built my own and didn't use a jack to install... thanks for the help y'all.
<A HREF=http://photos.yahoo.com/bc/tracetrimble/vwp?.dir=/rig&.src=ph&.dnm=104_0443small.jpg&.view=t&.done=http%3a//photos.yahoo.com/bc/tracetrimble/lst%3f%26.dir=/rig%26.src=ph%26.view=t>my new STB - cleanest part under the hood</A>
Old Aug 24, 2003 | 05:34 PM
Tibey's Avatar
Car: 1987 Chevy Camaro Z28
Engine: 305, 4bbl, A/C, T-Tops
Transmission: 700R4 4speed Automatic
I bought one (Edelbrock Strut Tower Brace for TBI/carb.) but in the rush to get it I didn't check that it wouldn't fit on cars with the A/C on the driver's side... does any one want to buy it? $120 takes it!
Old Aug 24, 2003 | 05:39 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
dude, we know you have one for sale, that is why we have a classifieds board, you don't need to reply to EVERY stb post on this board. post it in the classifieds, that is what it is for. leave the forums to answering and asking QUESTIONS.
Old Aug 24, 2003 | 11:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i already PMed him about it... he thinks im a dick or somthing...
Old Aug 24, 2003 | 11:28 PM
Dewey316's Avatar
Car: 1990 Camaro RS
no comment
BTW, he did PM me an apalogy for posting it so many times in the forums.
Old Aug 25, 2003 | 12:58 AM
OMINOUS_87's Avatar
It appears that this fool created his name for one purpose, I think he should be banned, what a joke!!!
He truely deserves the following award.
Tibey is a fine example of this.
Old Aug 25, 2003 | 11:37 AM
Tibey's Avatar
Yeah, the description might have applied to me for doing what I did yesterday, but BOTH, the description AND the picture fit you 100% better!
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
