Traction Action Lift Bars
Old Mar 27, 2003 | 11:23 PM
AFast83z28's Avatar
I was looking at Lakewoods Traction Action Lift Bars with the lower control arm. I talked to the guy that I am buying my cage from and he is running those. Has anyone run them? He said they run great. He cuts a 1.52 60 ft at 10.50s on slicks so is that decent or should it be better/worse? He is running stock rear end (gm gears, moser axles, strange mini spool) and stock torque arm (poly bushing). He was running 10.50s with only subframe connectors and these. Some opinions quick would be great! Buy or no? I can get them brand new for $100...
Old Mar 27, 2003 | 11:31 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
I made a post earlier asking about them...
https://www.thirdgen.org/techbb2/sho...hreadid=169614
No replies yet, but from what I see they are just a pre-manufactured LCA + relocation bracket.
They have my interest.. I'm just curious as to other thirdgens with them.
Where can you get them for $100? They are $199 @ Jegs..
Old Mar 28, 2003 | 07:24 AM
90formula5.7's Avatar
RE
I HAVE A FRIEND THAT HAS THEM ON HIS 86 Z HE MAKES A 1.60S 60 FOOTS BUT THE CAR HAS A LOT STIFFER RIDE NOW ., I HAVE SPOHN RELOCATORS AND MAKE THE SAME 60 FOOT WITH THE SAME CONVERTOR HE HAS WE RUN BASICALLY IDENTICAL MOTORS
Old Mar 28, 2003 | 07:59 AM
AFast83z28's Avatar
a friend has some the he never used so i was looking at them. essentially i am wondering is do they help hook and are they worth the money? when yoyu say stiffer ride, is it still tolerable for driving?
Old Mar 28, 2003 | 08:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have the regular Lakewood LCAs and Spohn reloc brackets. The ride quality was not affected at all by this installation. Plus, it's much simpler than the other, and I would expect, much more long-term reliable, since it's a single welded piece on each side with no extra joints, no hardware to clamp it around the axle tube, etc.
Personally I would not buy those. I like the setup I have. But I have no times to compare to.
Old Mar 30, 2003 | 10:31 AM
traction action bars
yeah the ride quality is tolerable but i really see no real effect in improve ments in 60 foots the control arm is in the same location as stock the only thing i see them doing is preloading the rear with those turnbuckles on them . best improvement would be relocators and boxed control arms!! i make the same sixty as my buddy with them!!
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
