brake problem, please help!
Old Mar 29, 2003 | 03:21 PM
DakotaSLT's Avatar
I was on my way home, and when I went to stop for a red, all of a sudden my brake pedal made a loud hiss, a small pop, then I lost all grab on the brakes. I managed to get home, but now my car won't stop at ALL. The pedal is very hard to push down, and hisses loudly. I *think* its the booster, but I have very little experience with brake problems, and I was hoping I could get some input as to what could be causing this. I'd really like to get the car back up and running soon, so any help and estimates on the time/money involved would be a huge help. Thanks guys.
Old Mar 29, 2003 | 03:23 PM
DakotaSLT's Avatar
It's an 88 Iroc, with 4 wheel disc brakes and the 9-bolt rearend, just in case that makes a difference.
Old Mar 29, 2003 | 03:34 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
probably a bad power break booster. ~$69 at your local parts store
Old Mar 29, 2003 | 09:26 PM
DakotaSLT's Avatar
Well, I played around with the car some tonight, and the brake pedal is very hard to push in, and hisses like mad when the car is on, still no brake pressure though. Trick of it is, you can only hear the hissing inside the car, not in the engine compartment ? I figured if it was a vacuum leak you'd hear it in the engine bay. Any thoughts?
Old Mar 29, 2003 | 09:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's the brake booster. That's what they do when they fail. The diaphragm inside it broke. You need another one.
Not much else to say.
Old Mar 30, 2003 | 03:08 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yup....... do as rb said and replace the booster.
Old Mar 30, 2003 | 04:59 PM
sllt1776's Avatar
Car: 89 Iroc-Z
yea most likely the booster...but make sure to check all the associated vacume line first just to make sure.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
overdriv
Aug 20, 2015 03:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
