Irregular tire wear..HELP!!
Old Apr 2, 2003 | 08:02 PM
denis's Avatar
Car: 80 Z28
Engine: just another 350
Transmission: th350
I am noticing the the outside edges or my tires are wearing low opposed to the rest of the tread on the tires. What causes this? cuz i don't want to have to replace 2 Falken ZR rated tires just yet!
thanks
Old Apr 2, 2003 | 08:10 PM
SgtSkip's Avatar
What kind of shape is your idler arm in? If it's worn you can go through tires like they're butter.
Old Apr 2, 2003 | 08:15 PM
91BlkRS's Avatar
could need an alignment.
Old Apr 2, 2003 | 08:17 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Sounds like a alignment problem.
Old Apr 2, 2003 | 08:55 PM
denis's Avatar
Car: 80 Z28
Transmission: th350
I was thinkin alignment too cuz the top of the wheels edge outward when the car is jacked up, but i was wondering if it might be a thirdgen specific problem
Old Apr 2, 2003 | 09:03 PM
DJP87Z28's Avatar
Not really, my Iroc had only one alignment in 16yrs and that was after a Idler arm replacement & new tires.
Old Apr 3, 2003 | 09:15 AM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
You're taking the corners too darn fast, slow down! (Yeah right)
I got the same 'problem' on freeway ramps.
Even though my alignment was in spec I loosend the three nuts on top of the strut and let it slide down about 1/4 inch for a little more camber on the dr side, pass side was all the way down already. That seemed to help handling a bit and tires dont show any abnormal wear. Good luck.
Old Apr 3, 2003 | 09:23 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, sounds like alignment.
The stock alignment specs for these cars produce that. They are stupid.
Get the car set to about -1° camber, with a ½° split (higher on the right); and +3-3½° caster, split similarly; and about .01-.02" toe-in.
And of course, make sure all your steering components are tight.
Old Apr 3, 2003 | 10:49 AM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
i did my idler arm and both ball joints last year then had it aligned and new tires put on...... and im still wearing out the outside edges of the front tires, it must be my driving (i seem to like to whip turns alot)
Old Apr 3, 2003 | 03:49 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
The top of the wheels edge outward when the car is jacked up because the A-arms are dropping down and changing the angles of the front suspension.
When you say the outside edges of your tires are wearing low, do you mean more or less wear than the middle? If tires are under-inflated, you can get excessive wear towards the edges of the tires. If the tires are over-inflated, you can get excessive wear in the middle of the tires. If the tires are out of alignment, one side or the other of the tire, but not both, will wear more irregularly than the other, depending on which way it is out of alignment.
I'm not considering myself to be an expert, but I read a magazine article once that had pictures in it and showed different wear patterns. Also, if you think about the physics behind it, it makes sense.
Eric
Old Apr 3, 2003 | 07:25 PM
Breadfan's Avatar
sounds like to much + chamber . have the alignment re checked ,this time give your car about .5 degrees neg camber , and as much caster as you get out of the stock setup .
Old Apr 4, 2003 | 11:06 AM
denis's Avatar
Car: 80 Z28
Transmission: th350
Thanks for all the replies, i'm gonna have it checked out.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
