E-Brake Weights......What are they there for????
Old Apr 13, 2003 | 08:21 PM
Stang Eater's Avatar
I'm swapping a set of rear disks from a 95 T/A onto my stock drum rear end.....and ran into a problem- The weights wont clear! Since the 4th gen rears are wider, but the suspension is the same, the LCA mounts are further away from the caliper, providing necessary clearence for the weight. My question is, what are they actually there for?? It can't be for e-brake return, because the whole bracket for the ebrake system is bolted solid to the caliper, and uses a spring for return. For now I have removed them, and the brakes are all bolted up, just have to make lines, and bolt the rear back in. I want to get this thing going next weekend so any help would be great.
Old Apr 16, 2003 | 12:36 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
If you have the aliminium calipers & if what i think your refering to(their round right).thay are for the calipers.Basically sometimes when you back-up.The calipers(because theyre lighter than cast iron calipers)make a humming/groan like sound.the weight just makes the caliper heavier to reduce the noise,which is mostly due to rotor(may need to be resufaced).By the way if you arent going to but them back on.What would you want for them...
Old Apr 16, 2003 | 08:57 AM
The weights??? As long as I dont have any problems you could have them.....but your in Cali and Im in Canada!
Old Apr 16, 2003 | 11:02 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
can find out a shipping rate.thanks
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
jawzforlife1
Apr 25, 2002 03:36 PM
The Dirty Bird!
Apr 1, 2002 02:36 PM
stuart69427
Feb 22, 2002 08:38 PM
88transam5.0
Dec 19, 2001 06:58 PM
