thinking of lowering, need info . . .
Old Apr 14, 2003 | 05:37 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
i was thinking of getting the Eibach Pro - Performance Lowering Springs-which lowers the car 1.25 inches, are these good-i don't want to go any lower- and what do you guys recommend-getting new shocks as well? if so, which ones-for a decent price -
and on the honeycomb gta wheels, i have 245/50/16 right now, does any company make say 245/45/16? and how wide can i go on those rims .. .i thought i heard 255's.. .
thanks
Old Apr 15, 2003 | 09:07 AM
MdFormula350's Avatar
umm, the prokit most of the time doesnt lower the car hardly at all, because usually the springs are sagged from years of use.
i have a prokit waiting for install at my house, should at least give take a tad more wheel gap out.
as far as tires.
you can go to www.tirerack.com and actually search for a certain size.
i ran asearch for you, looks like 27 results for that size and a wide range in price and performance.
good luck.
http://www.tirerack.com/tires/Compar...rk=1&do=Search
Old Apr 15, 2003 | 11:38 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have the Pro Kit Springs.
Not much lower than the old sagging stock springs.
I cut 3/4 coil off the fronts and removed the isolators front and rear.
The KYB shocks /struts are inexpensive and are a good improvement over the stockers.
If you have $ to spend, get Bilsteins or Konis.
I have the 16x8" (92 Camaro Wheels) and I'm currently running 245-50-16's in the front and 255-50-16's in the rear.
I ran 245-45-16's for a couple years. They were a little stiffer, due to the shorter sidewall, and looked a little funny in the rear. If you're gonna use 45 series tires, I'd only run them in the front.
255 is the widest recommended for an 8" wide wheel.
-Rich-
Old Apr 17, 2003 | 02:28 PM
91fbirdgta's Avatar
ok cool, thanks guys for the info . . .got another ques-since i have the so called "performance package" w/ my car, i heard that by lowering it, it might mess up the suspension-
thanks
Old Apr 17, 2003 | 02:48 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Axle/Gears: BW 9 Bolt/3.70
using the eibach pro-kit or sportlines will not lower your car enough to give you big problems with the suspension. both will still allow you to get a good front end alignment without any augmentation. they will change the geometry in the rear and you would benefit from lca relocation brackets. not an absolute necessity but you will spin the rear tires easier than before without it.
as mentioned before people with the pro-kit typically do not experience much drop if their stock springs are worn (at this point in time most are). i went with the sportlines and found that conventional wisdom on the board that these are too low was unfounded. i did replace all of my isolators when i put the new springs in. the pic in my sig is the stance with the sportlines.
the only other item that you may want is an adjustable panhard bar. again, not an absolute necessity but lowering your car will push the rear end out toward the passenger side slightly (about 3/4" IIRC).
-Schultzy
Old May 13, 2003 | 12:30 PM
FIII's Avatar
Car: 88 Formula
Schultzy89GTA,
You say the rear will be pushed toward the passenger side. I have the pro-kit in my Formula and I'm seeing the exact opposite, mine is pushed 3/4" towards the drivers side. Anyone else notice this or is mine a freak?
Old May 13, 2003 | 12:42 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
no toward the drivers is the dirction it will go, due the the location of the panhard and the arc it moves in.
so you nor your car is a freak
Old May 13, 2003 | 01:32 PM
DreamState21x's Avatar
pro kit
I have the pro kit and at first it didn't really make a difference but after about 6 or 7months it looks alot better.. Only problem is that the driver side front and rear sits nicely but the passenger side rear sits one inch higher and the passenger side front sits 1/2in higher... Havn't figured out why yet.. no one really notices it but I can tell and Ive messured... Anybody have any ideas on this one..
Old May 13, 2003 | 01:52 PM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
I installed some suspension techniques springs with KYB struts and springs. To make sure the car would not bottom out on large bumps I installed a rubber spring helper. (this prevents the springs from a full compress state thereby not subjecting the shocks to take on the full bump). So far I am happy with the set up. Its resonably comfortabel and handles well. It also looks great. The drop in front was 2" and about 1/2' in rear.
Old May 13, 2003 | 06:41 PM
Car: 1989 GTA
Originally posted by FIII
Schultzy89GTA,
Oops
My bad. That is what I get for going from memory. Thanks for the correction FIII and Dewey.
-Schultzy
Old May 13, 2003 | 08:10 PM
SDCal7's Avatar
I bought the same springs for my conv but the rears were way to soft. I had to buy springs from Gulstrand and cut them to fit. Much better. The fronts aren't bad but I've got a lighter engine now.
customblackbird
Aug 15, 2021 10:16 PM
9192camaro
16
Feb 3, 2019 12:21 AM
midge54
Jan 29, 2017 07:00 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
