Question on converting to 4th gen brakes...
Old Apr 14, 2003 | 11:10 PM
CamaroX84's Avatar
I'm getting a Strange 12 bolt rear end, and it only accepts 93-97 disc or drum brakes. My current brake setup includes the 1LE front (12" rotors and dual piston aluminum calipers) and 89 Trans Am rear brakes (12" rotors I believe). So I'm guessing all I need to convert the rear is the calipers, rotors, and possibly the hoses from a 4th gen. Is this correct? Also, will the proportioning valve/master cylinder that I have now work with these brakes, or is something different? Any help would be greatly appreciated. Thanks.
Old Apr 17, 2003 | 12:29 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Look here for more specifics on the swap.
http://members.fbody.com/86firebird/ls1/ls1brakes.htm
I think you will be fine since you already have the 1LEs and the rear calipers are virtually the same.
Good luck with the swap!!
HTH...Ed
Old Apr 17, 2003 | 02:54 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You just need the 93-97 caliper mount plates and rotors, i have both used if you're interested...
Old Apr 17, 2003 | 03:25 PM
ebmiller88's Avatar
Oops...my mistake. I replied concerning LS1 brakes, sorry.
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
redmaroz
Aug 16, 2015 11:40 PM
dhonda200
Aug 11, 2015 11:50 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
