Pro Kit
Old Apr 15, 2003 | 11:08 PM
87-5.7iroc-z's Avatar
Car: '87 IROC-Z
Engine: L98 TPI/Possible LS1 swap
Pro Kit
Has anyone cut Eibach Pro-Kit springs? Didn't set right after install. Alittle high for the money.
Old Apr 15, 2003 | 11:26 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Yeah, not much lower than the old sagging stock springs.
I cut mine.
About 3/4 coil in the front. Left the rears alone, but I don't have spring isolators.
Sits right where I want it now.
-Rich-
Old Apr 15, 2003 | 11:36 PM
Car: '87 IROC-Z
progessive
It didn't mess up up the progessive spring? These springs raised my car up.
Old Apr 16, 2003 | 12:03 AM
Car: 92 Camaro RS
Only the rears are progressive.
-Rich-
Old Apr 17, 2003 | 11:08 PM
Car: '87 IROC-Z
bump stop
Did this kit put you to riding on the bumpstop? The springs were not put in correctly the first time. ground to fender in front is 25 3/4 and the back is 26 3/4. Should that put me on the bump stop and can you trim the stop down some?
Old Apr 18, 2003 | 11:07 PM
Car: 92 Camaro RS
On mine the front is 25-1/4" and 26-1/4" in the rear (top of opening to ground) This with 255-50-16's rear and 245-50-16's front.
Bump Stops need to be cut (majorly) or replaced with shorter ones.
I bought very short poly bumpstops (5/8") but had to shim them up to get them to work (so short the A Arm hit the frame, stop never touched)
a Poly 3/4" or 1" Bumpstop would probably be perfect.
I'm using Ground Control Caster/Camber Adjusters that increase front strut travel by about an inch on lowered cars.
-Rich-
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
jbates346
Oct 21, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
