Best alignment settings for a car that....
Old Apr 16, 2003 | 04:06 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Needs the maximum settings for handling and racing. What is the recommended caster, camber, etc.
Thanks.
Old Apr 18, 2003 | 12:07 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
well if you are talking autox then use as much negative camber as possible. then as much positive caster as possible. to set for .06* total.
Old Apr 18, 2003 | 12:53 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I set mine to -.5 degree camber,+4.5-5 degrees caster,1/16 toe in.
Old Apr 19, 2003 | 01:57 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Well the suspension guru Herb Adams recomends,
Street,
Camber -1
Caster +3
Toe 1/16".
Autocross
Camber -2
Caster +5
Toe 1/16"
Old Apr 19, 2003 | 02:19 AM
Administrator
Well what would the best "blend" be??
Old Apr 19, 2003 | 02:48 AM
CrazyHawaiian's Avatar
Car: too many ...
https://www.thirdgen.org/techbb2/att...postid=1180408
Old Apr 19, 2003 | 02:56 AM
Administrator
Thanks, I guess hard street use would be it?!. If that would be the best compromise between racing and handling.
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
