ttop squeaks
Old Apr 21, 2003 | 03:33 PM
jbcmyk's Avatar
ttop squeaks
installed sphon sfc's and noticed a difference in stiffness.
i still have some t top squeaks and dash rattles.
will anything quiet this car?
(not that is too noisey)
how about strut tower braces? or would i have to include a roll bar?
eibach pro springs, new poly bushings front end kit shocks and struts.
Old Apr 21, 2003 | 05:01 PM
Thunderboy's Avatar
Car: '90 Camaro RS T-Top
Engine: 5.0 TBI
Transmission: TH700R4
Hey JB, I don't have yet SFC's on my car, but I ran into this fix a couple days ago.
I was painting the black edge molding on my T-Tops, and noticed that the holes in the A and B pillars where the lock pins engage were dirty and with a kinda powdery residue. I cleaned it all up, as well as the weatherstripping and channels. Then i put just a small dab of #2 chassis grease in each hole, and smeared it around.
Then I just put the T-tops back, and the car is a lot quieter, it seems a lot of the squeaks were due to the locking pins rubbing into the holes.
hope that helps,
Old Apr 21, 2003 | 10:59 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
I use WD40 on the gaskets around the T's to quiet them down, I've never heard of the pin thing before, but I'm gonna try that.
Of course you could just ride around with the wind in your hair, they don't squeak when they're not in
Old Apr 24, 2003 | 09:09 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
Re: ttop squeaks
try some silicon spray on your tbar rubbers,,(also helps rain from getting in too) thats what the dealler does for new car rubbers squeeks.
And SFC and/or STB wont EVER get rid of your dash ratteling unless you attach your sfc to your dash somehow hahahaha.
seriously tho buy some silicon spray its a must for someone with ttops belive me!!!!!
JC
Old Apr 25, 2003 | 08:50 AM
drsmithson's Avatar
Car: '91 Camaro RS
Engine: TBI 305... bah
Transmission: Slushbox 700r4
i have to agree with Frik here, just take 'em out!
i replaced the weather stripping on the t-tops alone last weekend and my squeaks have nearly gone away, and my car doesn't leak nearly as much either. just a note: if you do replace the weather stipping, i'd recomend replacing the rubber awning while you're at it - looks a lot better and helps with leaks a lot too.
doc
Old Apr 27, 2003 | 06:26 PM
Camaro_nut's Avatar
After I had installed the Jeg's subframe connectors in
my RS, 80% of all rattles/squeeks were gone. Not to
mention how much more stiffer the ride and handling
is! I also replaced my leaking/worn out T-top seals
and the T-top frame that sits on top of the roof. About
10 hours worth of hard work, 90% of rattles/squeeks
gone, also 90% of water leaks gone too!
I don't think you can get rid of all rattles in our
cars. Even if you install subframe connectors,
a strut tower brace and new t top seals. Remember,
there's NO roof! But you can minimize the rattles
and squeeks! My subframe connectors alone
eliminated most of the noises!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaysfs
Exterior Parts for Sale
Sep 18, 2015 11:59 AM
MORREALE5
Sep 13, 2015 09:01 PM
scottmoyer
Sep 7, 2015 07:06 PM
Victor6
Aug 30, 2015 02:09 AM
