On the front caliper does it what mounting bolt you put where?
Old Apr 24, 2003 | 11:54 AM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I may have mixed up the caliper bolts when putting the caliper back on the car can one go on top and one on the bottom and vise verus or are they made to go only in one spot? One seems to be a little longer then the other,thanks
Old Apr 24, 2003 | 01:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are supposed to be the same.
Somebody probably replaced one, and the new one is slightly different.
If it bothers you, a pair of new ones is about $5.
If yours have any visible wear where the pads or the caliper contact them I highly recommend replacing them. I change mine every couple hundred thousand miles whether they need it or not, just to keep that fuzzy feeling going.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
sailtexas186548
Jan 19, 2016 12:21 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
