metallic noise...
Old Apr 24, 2003 | 06:36 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
metallic noise...
ok, im getting a metallic sounding noise coming from under my car. im at school right now so i cant really put it up and look at it. i was hoping just to get an idea of what it could be...
1. it only happens when theres 3 or 4 people in my car...
2. it gets louder when i hit a bump...
3. when i brake it goes away...
4. sounds like when someone hits the spokes on a wheel with a stick...it makes that claddering sound that gets faster as the wheel increaes speed.
any ideas? i think it has something to do with the suspension compressing and maybe rubbing against something.....
Old Apr 24, 2003 | 11:48 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
You nailed it with that suspension rubbing idea (almost). It's probably some cable, brakes maybe, somewhere near the driveshaft that when the car is loaded rubs against it. When you hit the brakes the line flexes away from the shaft and the noise dissappears.
OR
The same thing but near the wheels instead of the shaft.
Old Apr 27, 2003 | 08:09 AM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
or it could be your upper panhard bar against your exhaust on the passenger side where the pipe comes over your axle, but it stops while breaking, thats because the load gets shifted foward taking the load off of the rear suspension, look at your exhaust pipe if it has dents in it by the panhard bar ill bet thats your culprit
Old Apr 27, 2003 | 09:20 PM
curt86iroc's Avatar
Car: 1990 IROC
i got the culprit. one of the e brake lines came out of the guide and was hitting the driveshaft...
Old Apr 27, 2003 | 11:03 PM
Spdfrk1990's Avatar
my car made a sound just like that when a sway bar end link broke.
MrPackstin
Oct 25, 2017 08:09 PM
Night rider327
Feb 25, 2016 09:50 AM
bigjay89gta
Oct 15, 2015 08:04 AM
Numbah-1
Oct 2, 2015 08:27 AM
sjorgens
Oct 1, 2015 07:54 PM
