What does this mean? LCA stuff
i keep hearing about "boxing" your lca arms, does this have somethin to do with your stock lca's and you somehow modify them or does it just mean to simply buy a new pair of lcas?
I've never done it myself so I can't speak from experience. Check this post though. https://www.thirdgen.org/techbb2/sho...hreadid=175686
Car: 4
Engine: 6
Transmission: 5
It helps somewhat, but is far less effective than just getting decent ones in the first place. They're not very expensive and are very easy to change; personally, for as little money as better ones are, I wouldn't bother to go through the hassle of fooling with stock ones. I'd suggest the Lakewood ones: just the LCAs, not their "traction action" kit, which IMHO is the wrong way to go about solving the problem.
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
It helps ALOT on straight power runs. It's not AS effective around corners, as the tubular aftermarket ones.
You really can't get any stronger than a box of steel.. tubular ones help from side twists, but not as good as boxed on straight aways.
It's VERY worth it and VERY inexpensive. Couple bucks for about a 1/4-3/8" Flat sheet of steel... C clamp it to the LCA and weld the edges forming it around. I did mine today, and like the guy was saying, it felt like the rear was RIGHT THERE. You give it gas, and you feel you move.
ALSO you need to put in POLY bushings, because heating LCA by welding can cause the rubber bushings to become slightly sloppy. Not to mention, Poly is better anyway.
I did both.
I did both.
LT1Formula
Oct 8, 2015 08:34 PM
